Wheel cap kit
I ordered the Bear set and I am splitting the set with Amster. (I'm taking the lug covers) I'm trying to order the black Lucid caps but it's like pulling teeth. I've called two service centers and they say "we will make a note on your account and let you know". Crickets. Does anyone know the easiest way to order these?
That's strange. Although, maybe for Lucid not totally unexpected. Why put them up for sale if they're not available?
I know members here have had success ordering them from Lucid direct. Me not so much. The bear caps are on the site for order probably because thase are an "accessory" but the Lucid script caps are probably considered a "part" as they come on every car.
So the bear center caps (link in the OP) work with Air, correct ?
Also,
Just need a small suction cup, it's super easy.
Is the suction cup needed to remove Aero covers, or just for (when) removing center cap to put the aero covers back in?
Just a heads up on these. You can't use them on the older 19" Air wheels unless you remove the aero inserts. As I discovered today, the center cap is molded with the aero insert as one piece.
