- Dec 20, 2024
New '25 AT as of December, on 2.6.2. Overall, pretty happy with what's now called Drive Assist (highway assist on DDP). Reading past posts, I feel lucky to have gotten the car at a time when many improvements have been made to DDP. That said, the lane centering adjustments are a bit rough (not fine tuned) in my few uses, which got me wondering whether it's possible for Lucid to improve the smoothness of the lane centering. Just curious, what would it take for Lucid to improve the smoothness of the car's ability to maintain the car centered in the lane (excluding all other scenarios such as assisted lane change, etc) - where is the bottleneck in the car's systems? Can this be done solely by software? Does the CPU handling the feature have enough horsepower to do it at a faster rate? Do the sensors provide sufficient information for this to be done more smoothly? (frame rates for video, precision, etc). Can the steering be controlled in any smaller increments or is it already at the limit and requires the 'rough' approach just because the steering wheel can't be controlled more smoothly or in finer increments by the car? Is it a data issue - is more data gathering on Drive Assist actual performance needed and fed back into algorithms on control? I assume the bus rates and data rates are sufficient for any improvement. So, what is the bottleneck in the process and can it be 'improved' in the future (with the assumption that h/w changes on existing cars is out, so if it's h/w, then it can't get better). Reference speed of 65-70ish mph.
