- Aug 22, 2024
- Air Pure
Sometimes I can't initiate the charge through my EA app. Is there any way to prevent plug and charge through Lucid so that I could use my EA account to pay for charging?
Why are you using the EA app when it can be all handled through the Lucid App?Sometimes I can't initiate the charge through my EA app. Is there any way to prevent plug and charge through Lucid so that I could use my EA account to pay for charging?
Per @marqie Post in thread 'EA Megathread'To use the EA pass discount.
...and I take it that the rate you are being charged through Lucid is higher, or you wouldn't be wanting to switch. I have not activated the Lucid Charging - Base Plan, so I can't see the details, but does it allow you to select which vendors to run through their infrastructure, such that you could just turn EA off? Or, does it allow you to enter any specific vendor discount codes into their system? I can see why they might not have the former, because you would not be plugging into their charger if you didn't want to use them, but it seems like the latter option should have been built in, or that Lucid should have pre-arranged a comparable rate plan discount. Sorry. Grasping at straws here.Initiation with the EA android app is spotty for me. Sometimes it'll initiate fine and I get charged through the EA app. Other times it'll hang at the initiation screen and I would have to plug in first to begin the charging and get charged through Lucid.
Just talked to CS and they said that removing the cc from the Lucid wallet should remove the plug and charge. I couldn't remove the subscription plan from the upgrade section however as there was no option. I'll try and charge in a couple of days to see if this works.
