- Dec 3, 2022
- Visalia, CA
- Lucid Air Grand Touring
- ZAJRISAL
I want to learn how secure Lucid is against car thefts.
This is what I think: If a hacker can physically access the CAN bus in a car, it’s possible to steal, provided there's sufficient time for the job.
The video in the article below recorded how thieves could steal a Lexus RX in 90 seconds by accessing the headlight through the wheel arch.
Headlights are controlled by ECU (electronic control unit). A thief can reprogram the ECU to unlock the door and drive away after accessing a headlight. Thus, it's called CAN Injection.
Watch Thieves Steal an SUV in 90 Seconds, the Key Fob Doesn't Need To Be Nearby
It's unknown if a PIN requirement would prevent a thief from driving away or if the thief could also bypass the PIN.
However, there are quicker ways to steal a modern car: Copying or amplifying the fob's signal can unlock the door and drive away as if the fob is inside the car. The videos show a relay attack where an antenna/tablet can pick up the fob's signal inside the house while the car is outside. The signal is then amplified so the car can pick up a strong fob's signal as if the fob is next to or inside the car:
After these incidents, there's an option for a PIN requirement for this particular brand even when the thief can open the doors. It’s a hassle for an owner to choose the option to enter the PIN at each drive session, but I haven't heard a car with a PIN requirement to drive is stolen by a relay attack.
Lucid does have a PIN option when you leave the card to the valet, but the valet can bypass the PIN by reaching up to the ceiling above the right shoulder where the “Y” is.
