- May 21, 2022
- Bay Area, CA
- Air Touring (Dream Rims)
- SU5XF4DI
Hi All, I recently had a HiFi upgrade done on my Lucid. To give you a sense of budget envelope, it was low 5 figures. So a serious upgrade.
I will be sharing learnings, pics, my experience thus far so hopefully other owners can benefit from understanding "what they will get" with the Atmos Surreal Sound system and likely what to expect with the Standard Stereo system. Also what's practical for audio upgrades.
The work was done by Sound Innovations here in the Bay Area, they specialize in Car Audio / Hifi systems. I'm a past customer (They did my Model S) so i knew what to expect. This was their first Lucid Air, so i was the guinea pig , that said they did an excellent job. (AFAIK no one else has posted a professional HiFi aftermarket implementation so maybe I am the first?) I know some Garage engineers have done some work on the Bass side.
Instead of doing a mega post, I will build the thread out over several sections so hopefully run the thead in more of a Q&A fashion. We will start with what you get with the factory system.
What you get with the factory system
Notes for consideration
- Excellent speaker placement for a car. The location of the of individual speaker components were extremely thoughtful to minimize standing waves, reflections, reverberations etc (in laymans terms it means that the speakers are not fighting each other when playing music). It was clear the audio system was part of the system design and not just an afterthought of (where do i jam these things into the car?)
- Particuliarly, as others have noted, the front stage mid-bass drivers are in the footwell panels (it's actually around the level of the dashboard, which makes it expensive to modify since the dash would need to be disassembled to access the mid-bass drivers) This positioning is ideal for imaging since it's wide and deep and not in the door panels which would narrow the stage and doors are notorious for footwell standing wave issues and imaging problems.
- Dual DSP Ampliiers (SSP)
- The Base Audio system basically has a single Class D DSP/Amplifier. The channels are actively managed so no passive crossovers in the car. The SSP audio system adds an additional DSP Amplifier to cover the Atmos channels primarily. Note the label for "BASE" and "PREMIUM" on the amps.
- Quality "OEM" Drivers.
- The drivers are quality on par with OEM upgraded European sound systems. E.g. B&O or Burmeister for Mercedes. Pressed metal chassis and ferrite magnets. (The Sub / Midbass have plastic chassis). The cones are paper / poly. If you were to buy then off the shelf they are equivalent to $50 drivers in terms of quality. All serious aftermarket drivers with neodymium magnets, textile/metal driver cones, metal chassis will perform on another level.
- Factory Tuning
- The tuning that was measured was for the stereo configuration as the Atmos system is harder to effectively play sweeps / tests for. What's interesting was that the output from the factory head units had very little correction put on the signal.
- This is either because the stock speaker placements were so good that little needed to be done OR they tuned for atmos and stereo was an afterthought.
- The "Subwoofer" in the back is basically an 8 in midbass driver with dual voice coils. Apparently it was crossed over quite high, running as high as 250hz down to 30 hz. This tune caused some phase issues with the front midbass drivers since they overlapped in frequency much more than typical for a subwoofer.
- The installer will share the test sweeps he did on the factory system / aftermarket system later this week so I can share then.
- If you opt for SSP, you are basically paying for the atmos license, an extra DSP amp and the height channels. (Maybe they downgrade the drivers too, we'll see)
- I think that where Atmos mastering is at today is kind of like when 3d movies first came out (and before James Cameron got his hands on it) kinda interesting, a little gimmicky because artists / engineers haven't figured out what to do with it, but has potential to do new and different things. Will take some time for things to catch up.
- If you plan to just run Stereo (and plan to do aftermarket work) the base system is fine since you'll end up replacing most of the components anyways.
