- Jan 3, 2022
- Santa Clara County, CA
- Air GT, XC40 P8 EV
- 3OKY7YGA
Many electricians do not seem to be aware that Leviton's $9 14-50 receptacle from Home Depot can be dangerous when used for EV charging.
For best long-term safety, have the electrician hardwire your home charging station instead of mounting a receptacle. This means running electrical conduit directly to the charging station, eliminating the need for a receptacle, cord and plug. The cost should not be significantly different than having a potentially dangerous 14-50 outlet installed. You can also get faster charging from a hardwired charging station if installed on a 60-amp or 80-amp breaker rather than the 50-amp maximum breaker allowed on a 14-50 outlet.
If you must use a 14-50 outlet, it should be an industrial-type receptacle made by Hubbell, Bryant, or Cooper. Leviton's $9 14-50 outlet from Home Depot can be a fire hazard when used for charging an EV. To see what kind of receptacle your electrician installed, turn off the circuit breaker to the outlet and remove the outlet's cover plate. The receptacle manufacturer name will be clearly stamped on the metal plate that supports the receptacle.
If you find that you have a Leviton receptacle, have an electrician swap in one from Hubbell, Bryant, or Cooper. The receptacle costs $75-100, plus labor. Don't try to do this yourself - the receptacle screw terminals should be properly tightened with a torque screwdriver.
Some firsthand experience talking:
