- Aug 23, 2020
- Paradise Valley, AZ
- Lucid GT
- K9WIJHB0
Not currently.Can we turn seat heaters on???
Once you're in the seat and you turn them on, the seat is hot in a minute. I can't even do the top strength of the heater, too hot for me.Not currently.
Not right now, maybe in the future?Is there a way to turn the rear defrost on from the app? When I defrost from the app it only defrosts the front, but I can’t see why you would ever want to defrost the front without also defrost the back?
This is a very dangerous assumption to make.How can this possibly be hard to implement, and painfully obvious as a necessity in winter? 20 lines of code?
I hear you, Joe. I am genuinely curious how this is hard to implement. Let’s get ‘er done!This is a very dangerous assumption to make.
As we would say in the business, it's not the 20 lines. It's the 20 hours it took you to figure out the correct 20 lines.
And then the two weeks of debugging all the regressions that happened because of those 20 lines.
Looking at Lucid's software development team, the number is probably quite low so they're limited on how much they can get done.I hear you, Joe. I am genuinely curious how this is hard to implement. Let’s get ‘er done!
It’s not that it is hard or easy, it’s about priorities. Every single person thinks that his own suggestion should be first priority. Accessing defrost from the app, in my world, is extremely low priority. I imagine they’re trying to balance importance to the general group with the amount of time and resources they have available.I hear you, Joe. I am genuinely curious how this is hard to implement. Let’s get ‘er done!
I haven't tested if, but does the defrost option in climate control only do the front defrost and not the rear?It’s not that it is hard or easy, it’s about priorities. Every single person thinks that his own suggestion should be first priority. Accessing defrost from the app, in my world, is extremely low priority. I imagine they’re trying to balance importance to the general group with the amount of time and resources they have available.
Correct, it does not turn on the rearI haven't tested if, but does the defrost option in climate control only do the front defrost and not the rear?
