- Dec 17, 2021
- Greenville, SC
- Sapphire - Dream Edition
- DE Number
- 40
I had a couple weeks away from the car and returned to build 1.1.91. My concerns are about the same. My concerns are still how annoying (to me) some basic functionality is.
Unlock/Lock, Homelink, Park distance Cameras. Never had a complaint with these systems in any other car.
For me the Air is only a few fixes from being a truly great car. Frustrating that my complaints are with systems that are no brainers in even a 25K vehicle from Mitsubishi.
My short wish list first, with more details and a comparison to a recent rental below.
1. Unlock/Lock Is still so inconsistant with no customization
2. Homelink can take 5 screen presses to shut one door
3. Park distance / cameras I find to be the worst of any car I have ever driven
The right cockpit panel is not easy to use while driving. Items are layers deep, not intuitive. The Pilot Panel UI/UX is far superior to anything on the right cockpit panel.
The Pilot Panel only has Music, Nav, Phone as a pull down from the Cockpit panel.
I compare the Air to my rental a $25K Mitsubishi Outlander with a CVT. It could do 0-60 in the 1/2 mile and 0-80 going downhill.
After loading my luggage and inspecting the car.
Upon getting in the vehicle, I adjusted the seat. Got a lightning cable and my sunglasses out of my briefcase. Plugged in the iPhone. Adjusted the mirrors, mirror controls on the door same as 90+% of cars on the road. Looked at the controls, lights on the left, wipers on the right, AC on Auto. Started the Car, Audio was on Sirius, which was active, great, confirm use of carplay on the car screen, confirm on the iPhone. Press go on the destination already entered on my phone. Shift in to reverse, park distance/camera easy to use and understand. Back out. Drive off.
Less the loading of luggage and inspection, all of this was done in less time than it takes the Air to Boot and play the radio.
Who even knew Mitsubishi was still selling cars in the US?
Outlander Unlock/Lock
Upon approach, courtesy lighting came on, one touch to the handle unlocked driver door, a second touch would unlock the rest of the doors. Worked exactly the same, every time, first try every time. Upon exiting the vehicle a single touch to the door handle locked all doors. Worked exactly the same, every time, first try every time.
Outlander Park distance cameras Smooth image, clean clear graphic, easy to use
Outlander Entertainment system. Fast Boot time. Sirrius, Carplay, radio worked every time, easy to change sources, easy to scan FM.
Outlander Homelink (Did not use)
Outlander Bluetooth (Carplay used)
Outlander Nav (Carplay used)
Air
Unlock
Upon approaching the car, the car may unlock at any distance between about 20 feet and 0 feet, or it may unlock after standing next to the car for a few seconds, or it may require a press of the handle to unlock, or it might require use of the key fob button unlock. Having to get out the key fob to enter only reminds you that the system did not work properly and that the key fob is not very good either.
Locking
Everything in the car will continue to operate including audio books / podcasts, or radio, HVAC, and all displays even after you are in Park and have opened the door. After you exit the vehicle, the Air will lock and turn off these systems. This will happen almost immediately or after an indeterminate amount of time, when you might be 60 feet or more from the car.
There is no customization, the operator can not turn the car “off”, it always unlocks all doors, no option for driver only, no option to turn off proximity, no comfort access, no lighting options, no lights/sounds options, you can try to lock the car by pressing the door handles, it may or may not have any effect.
Inconsistent and frustrating.
Air Cameras / Park Distance
The cameras have a lag. The lag from reality to the screen inside the car is enough to be nauseating. It’s uncomfortable to watch the screen while moving (somewhat the point of the system) due to what is on the screen not matching the information your inner ear is giving your brain.
The graphics overlays cover the portions of the image you most need to see. The car is not represented on the screen accurately to where it is in the outside world. The audio alerts are annoying vs informative and often go to full tone when you are in fact not that close to anything.
The Park distance camera screen UI doesn’t even match up well with the rest of the UI in the car. Lower navigation panel is not there. The Autopark and Surround view links as well as the “x” and “mute” can be easily lost in the image.
Boot time is long.
Previously connected Bluetooth devices may or may not autoplay
Navigating this system while driving is near impossible
Is a reminder every time that I would rather be using an app on my phone
Homelink
Leaving
Arriving
If Geo fence works press “Door” button. If it does not work or hides before you can press or the press does not open door, see above.
1-6 operations
Phone via Bluetooth
Connection does not work every time
Use occasionally locks up and requires a reboot to use any media
May or may not auto play source that was playing after call ends
Nav
Slow to find destinations
Short interruptions in cell signal confuse or lock up system
No volume control or voice prompt customization (on/off)
- Customization of Unlock/Lock is standard for this segment. Really any segment today.
- Proximity lock - on/off
- Unlock - Driver door/all doors
- A way to turn off the car (Press park a second time)
- Comfort access (seat moves back for exit) This helps many drivers with exit and helps if drivers of significant height differences share the car.
- Add bottom navigation and a side panel with Homelink buttons to the pilot panel Park/Camera screen
- This system needs a significant review and redesign using any of the Legacy car manufacturers as a benchmark. My reasons below.
Air
Unlock
Locking
Boot time is long.
Homelink
Leaving
- Press the “X” top of upper Cockpit panel
- Press the Profile area of Cockpit panel
- Press Homelink symbol
- Press “Door” to close. (May or may not work on first try)
- Press “Park distance” on Pilot panel
Arriving
1-6 operations
Phone via Bluetooth
Nav
