Tire Pressure Light stays on after swapping Winter Wheels/Tires (20") to Original Summer Wheels (21") on my 23 GT
frank4711
Supporting Member
Lucid Air GT
Hi there,
did anyone face the same issue? I got my summer tires on my 23 GT back on and the tire pressure light always comes on and stays on despite the fact that enough tire pressure is maintained.
Any idea to get rid of the "error"?
Thanks in advance
Hi there,
Thanks in advance
Have you driven over 20 mph? Sometimes it takes a while of driving to update.
Yes, several times and also set the right wheels in the settings to the summer 21" wheels/tires.
Hmmm. I haven’t encountered that before and have done it a few times on different vehicles/ Have you tried a hard reset and then drive to above 20mph, or on the freeway for 5-10 mins?
Sorry if this isn’t helpful, but trying to think of what I’ve done to get it to register.
There are two things to consider:
1. Make sure the tires have compatible TPMS sensors. Not all TPMS are the same.
2. You will most likely have to train the car to accept the new TPMS sensors. Some cars might relearn but most won't. I have never had a car that will relearn on its own. I use a 'ATEQ VT 30' that works really well.
I hope this helps.
I hope this helps.
Hey there,
Thanks. I ordered one on Amazon to give it a try and have a fast resolution. ;-) Is there anything to consider before "activating" the TPMS sensor?
Hey there,
With that TPMS scanner tool, you can also check the battery as well. It makes it pretty nice.
