I'm about to take delivery of my Lucid Air Touring in a couple of days. Can I expect to have a lot of software glitches?
Define.."glitch"I'm about to take delivery of my Lucid Air Touring in a couple of days. Can I expect to have a lot of software glitches?
Define "a lot"...Define.."glitch"
Probably several at least until March or April, my best guess.I'm about to take delivery of my Lucid Air Touring in a couple of days. Can I expect to have a lot of software glitches?
Exit the car, move out of key range, wait at least 45 seconds, return to the car and click the top of the key fob twice in quick succession. The horn should honk and the headlights blink if the reset succeededAlmost 2000 miles and the only issue I had were blind spot cameras not working one trip. Simple 45 second reboot fixed. Low price to pay for such an amazing cutting-edge vehicle
I've soft reset the car by just staying inside. See my post here:Exit the car, move out of key range, wait at least 45 seconds, return to the car and click the top of the key fob twice in quick succession. The horn should honk and the headlights blink if the reset succeeded
is this how you reset? how far is the key range? is there a way to reset without walking out of the car?
Yes, how exactly do you do a soft/hard reset?Almost 2000 miles and the only issue I had were blind spot cameras not working one trip. Simple 45 second reboot fixed. Low price to pay for such an amazing cutting-edge vehicle
this is how he did it - You can turn off the car by putting it in park, opening the door, closing it, then locking from the fob with a single press. That will shut everything down as if you walked away.Yes, how exactly do you do a soft/hard reset?
Maybe in the future there will be a sequence of button pushes on the steering wheel while in park that could reset the car. I think that would be a good idea. I’ll need to reset the car maybe once every two weeks or so? It’s usually because the audio quit working. Other glitches I’ve found don’t need a reboot, like cameras not coming up, are cured by just putting the car in park and then in reverse again. And I’ve had the pilot screen navigation freeze while the glass cockpit navigation was still working, so I just ended the route and then put it in again and it fixed it.With at least 3 different ways to reset/reboot the car, I'm wondering why Lucid didn't just put a reset/reboot button somewhere in the settings just to make the process easier.
