Does anyone know the Size of the rims? Width, offset? I'm waiting on my Grand touring order and went with the 19" rims for the range but I would like to look at some after market options. Maybe something lighter with a different design.
I asked the same queston! The response I got from DA was I would void the warranty if I put after-market wheels on, come on. As long as you get wheels rated for the weight we should be fine. This is the info I was able to dig up:
The Lucid Air 19” Aero Range wheel has a wheel width of 8” and will accept 5-lug 120mm bolt pattern wheels with a 64mm hub.
The 19” Aero Range wheels come with Pirelli P ZERO All-Season, LM1: 245/45R19 102Y XL
The 19” wheel can also support Pirelli Winter Sottozero 3, LM1: 245/45R19 102V XL
Lucid only endorses the 19” tire option as it was thoroughly tested
Wheels for the Lucid Air have been specifically designed for higher EV weight and aerodynamics and range and performance may be reduced with installation of aftermarket wheels or tires.
Keep in mind that Lucid Motors does not recommend aftermarket parts or wheels and your Lucid Air warranty may be affected should any damage occur as a result of an aftermarket product or non-Lucid certified service or installation.
Will OEM tires (245/40R20 (F) and 265/40R20 (R)) for Air Touring fit on a aftermarket rim with dimensions of 20x9"? Any help would be appreciated. Thank you
