Recommendation for a portable charger cable for NEMA 6-20?
So, not sure if this has been covered in this thread? My Lucid charger cable stopped functioning in 120 volt and NEMA 14-50/50amp outlets. Partner just got an XC60 with a NEMA 6-20 plug and wanted to use the NEMA 14-50 outlet. I saw Home Depot has a 50Amp 14-50 piggy-back plug with 6-20R connector adapter C (AC Works-PB1450620) which she used to Level 2? charge her Volvo. I'm assuming I can use her Volvo J1772 plug and 6-20 plug piggy-backed to the 14-50 outlet to charge my AT? Any concerns? (I have a heavy up panel and Bryant 14-50 outlet.)
Sure as long as your adapter is solid. By the way, the Lucid charger chould be under warranty. Worth a phone call to see if you can have it checked out and possibly replaced. Since you said it doesn't work for 120 or 240, it makes it less likely to be an outlet problem...
The charging cable / box uses the selection of plugs to adjust amperage drawn. It should deliver 20A 240 performance.
