Problems with Ford Home charger
revandspark
Gravity, Mache, Rapide,
We have a couple of Ford electrics and have the 80A home charger which the Starship (26 Gravity GT) doesn't charge from. (yes I use the correct adapter). Anyone else out there with this situation?
Please give us some more information. Does either the Gravity or the Ford charger (EVSE) show an error? Do you have scheduled charging set on either?
Hello,
Thanks for your interest in my little problem. The connection goes fine, Gravity says it's charging, and the Ford charger pulses like it's happy. Four seconds later the Ford charger clicks off and all comes to a halt. I should check the Gravity to see if it has a charging schedule set. Good thought, thank you,.. will advise.
Hello,
Replying to my own Post (lol)
Found out the reason, the adapter that Lucid supplies does not have the three pins that the Ford charger requires. It is a DC adapter and I need the AC adapter which which will charge the Gravity. It looks the same as the one supplied by Lucid but has three pins instead of one in the small barrels.
See State of Charge's video for the A2Z adapter needed for this.
