Lucid Charger and ChargePoint not working
Ms. Jones
Lucid Air
Do photos of connectors look normal or is something missing? My ChargePoint charger has been working for two years. Roommate borrowed it to charge Tesla now ChargePoint not working on my car? Any advice? My Lucid charger also not working. Message says 45days to charge???
Please tell us how the ChargePoint and Lucid charger are wired to your electrical panel. It sounds like a wiring problem that has deteriorated over time.
Thank you for replying. The Lucid charger is plugged into wall. I tried to use it for the first time. I’ve had it two years but never used it. I’ll attach a photo of the wiring for the ChargePoint. The Electrify America charger will work. I’m so puzzled…
Is your breakers for the 50 amp off? Or are they just installed backwards?
For that photo it is off. ChargePoint asked me for a photo showing it in the off position.
If I understand correctly, the ChargePoint is hard wired to the 50A breaker shown in the panel. What type of outlet is the Lucid Mobile Charger plugged into? I am glad that you are in contact with ChargePoiont becasue it may be an issue with it.
If your Lucid charger is plugged into a regular 120V receptacle, the car will charge very, very slowly, and a display of 45 days to charge may be accurate depending on garage/car temperature. I agree with @Adnillien that there could be an issue with your Chargepoint.
Yes the Lucid charger is just plugged into a regular 120 amp socket. This is so puzzling as the ChargePoint suddenly stopped working. Thank you all for your assistance.
