Is something wrong? 90% == 293 miles
Mostly 40 - 50 mph roads. No, I don't make it a habit of driving below the speed limit (+ 10%) unless the car in front of me presents a barrier. I mix that with interstate driving (70 mph) several times a week. The climate here is mild most of the year, so I don't need much from the air conditioner or heat pump. I use max regenerative braking of course. And I'm not the guy everyone honks at because I'm holding up traffic.
I think the AC is a huge drain on efficiency for those of us using it so hard as it was a very warm spring/summer/fall for a lot of us. I’m thinking as well the Gravity has a very narrow sweet spot for temps that make it happy. Like from mid 70s to upper 60s. Which of course would mean no or little AC usage. We have to get OoS or Tom out your way to get those numbers!
Oh - one more thing. It's leased, so if anyone wants it when the lease is up... (which would be December 2028)
I've never reset Trip B. Over the 10 months we've owned our Gravity GT we've averaged 2.98 miles/kWh. Ours is the 5-seater with 21"/22" wheels, so I think EPA is 407. Taking our average of 2.98 times the 123 kwH battery pack, we're looking at 367 miles of range. Kind of disappointing, to be honest, but it is what it is. We don't drive it hard, but do a lot of short trips, mostly rural roads and highways, with occasional long road trips at 70mph.
Note: The tire pressure display on the dash always read 42 psi. When I put an actual tire gauge on them, they were mostly 38 psi. Not sure how much of a difference that might make.
Researched the tire pressure comment. The miles/kwh drop from a true 42 to 38 equates to only 1 - 2%.
If anyone on the thread is around eastern Massachusetts, the Natick Lucid has a thing on Saturday. I plan to stop in.
What’s the event? I’m near Natick (no Lucid yet though)
FWIW, I get real impressive mileage out of my ‘23 model X when the weather is mild. New England driving is a lot of 30-40 mph driving, with scattered highway driving, and there’s almost always someone ahead of you on the highway helping to create a favorable airflow. Of course it helps to not be the fastest driver. I’m often close to 250-270 /3.8-4.0, in the shoulder seasons.
Thanks Marc for the data point.. hoping to get a Gravity one of these days and add an additional data point.
At mostly 40-50 MPH, without jackrabbit starts, getting significantly over 3.0 MPK is plausible. Before I started doing road trips in mine and was just doing local driving, I was getting around 3.3.
Not sure if you're go by the trip meter or the Dynamic Efficiency circle. The latter is frequently quite different and often misleading. The trip meter shows what you actually got.
Good points. I go by the trip meter and the kwh and miles traveled when I charge. (I do the second calculation occasionally; I don't obsess over miles per kwh.)
As soon as it got cold here my dynamic is like pre-dropping as if it's predicting the cold weather and heater usage will drop it back into the 2.7-2.8 range...
Have you actually done a 100% charge, re-set trip meter and run down to nearly 0%? I would be shocked if you're actually getting more than the EPA rating, but who knows? I hope that old Reddit AMA actually happens from Lucid at some point as there'd be plenty of questions about this, I think.
My Gravity GT is just over a year old now. I mostly charge at home and it always charges to the limit that I set. But it happened consecutively the past three charges that it charged over the limit. The limit was 85%, the actual SOC was 87, 87 and 86%, respectively. Not sure if this is a software or hardware issue. Did this happen to anyone else?
That's happened a few times on mine. Could just be the measurement is off a little. That's why one poster said to charge to 100% occasionally. Most EVs tend to drift some on their voltage and SOC% measurement without periodic calibration. Charging to 100% recalibrates it by establishing the upper boundary. It's a good idea to charge to 100% every few months. You don't want to do it every time because that's not good for battery longevity (batteries thrive most living in the 20-80% range), but it's good to do 100% occasionally.
Not quite - but I've taken it down to 21% from 100%. Close enough?
From what I understand, yes, you want to charge to 100% occasionally but not run it to 0%. Even though batteries like the 20-80% area best, it's worse on the battery to run it super low than to charge it full.
The charge issue from Lijunli is interesting; the reply from dbsb3233 more so. Here are two papers from battery engineers/developers:
That forum post is partly right in general, but I would not follow the “charge to 100% every few months” advice for a Lucid Gravity unless Lucid specifically tells you to.
Lucid’s own guidance is quite clear: for the Gravity, use the Daily limit—up to 80%—for normal use, and reserve higher states of charge, including 100%, for trips when you actually need the range. Lucid explicitly warns that frequent charging to 100% or letting the battery sit full can accelerate degradation.
The forum poster is correct about one concept: a battery-management system does not directly “see” state of charge. It estimates SOC from voltage, current flow, temperature, cell behavior and accumulated charge/discharge. Those estimates can drift somewhat. But modern EV BMS software continually corrects that estimate during normal operation; it does not necessarily require periodic 100% charging to recalibrate the upper boundary.
That advice is more relevant to some LFP batteries, whose voltage curve is unusually flat over much of their operating range. Because voltage changes so little with SOC, occasional full charging can help the BMS estimate SOC more accurately. The Gravity uses a nickel-rich lithium-ion chemistry, whose voltage/SOC relationship gives the BMS more information to work with. So the LFP-style “charge to 100% periodically for calibration” rule shouldn't automatically be transferred to the Gravity.
As for the 80% setting resulting in 85%, I would regard that as more interesting than a need for calibration. Lucid says the charging system is supposed to charge until the selected limit is reached, while dynamically adjusting for SOC, temperature and other battery conditions. A percentage or two of apparent variation after charging could reasonably arise from temperature changes and subsequent BMS estimation. Five percentage points repeatedly is large enough that I wouldn't simply dismiss it as normal SOC drift.
If it happened to me, I would do three things:
  1. Continue setting Daily to 80%. I would not start deliberately charging to 100% for calibration.
  2. Note whether the car actually stops charging at 80% and later displays 85%, versus actively continuing to draw power until the display reaches 85%. Those are quite different phenomena.
  3. If it repeatedly continues charging well past the programmed 80% limit, I would report it to Lucid—particularly because Lucid itself describes the setting as a maximum battery percentage at which charging should stop.
There is also no harm whatsoever from the battery occasionally finding itself at 85%. The longevity issue is cumulative exposure to high SOC, especially sitting near 100% for prolonged periods, not an occasional excursion from 80% to 85%.
So my reaction to that forum discussion would be: reasonable explanation of how SOC estimation works, but an unjustified leap to “therefore charge the Gravity to 100% every few months.” Lucid itself does not recommend that.
If you're still awake:
The Gravity uses a nickel-rich lithium-ion chemistry in Panasonic’s latest-generation 2170 cylindrical cells. Lucid’s regulatory battery data identifies the chemistry as Li MM(NRMC), which corresponds to a nickel-rich lithium metal-oxide cathode family rather than LFP.
For the Gravity Grand Touring, Lucid pairs those cells with a roughly 123 kWh battery pack and a ~926V electrical architecture. Panasonic and Lucid specifically developed the cell for high energy density, fast charging, temperature performance, and longevity; Lucid says the cells exceed 800 Wh/L volumetric energy density.
So, in practical terms: it is not an LFP battery. It is a high-energy, nickel-rich lithium-ion battery, optimized for range and power density—one reason the Gravity can get such long range from a comparatively compact pack.
This comparison is quite interesting because the Gravity, Model X, and high-range R1S all favor high-energy nickel-rich chemistry, whereas Rivian also offers an LFP alternative. Mercedes uses NMC811.
VehicleBattery chemistryApprox. pack / architecturePractical character
Lucid Gravity GTNickel-rich lithium-ion; Lucid codes it Li MM(NRMC)123 kWh, 926 VExceptional energy density and charging
Tesla Model XHistorically NCA, Panasonic cylindrical cells; Tesla does not publicly specify every current pack detail~100 kWh, ~400 V classMature, high-energy-density design
Rivian R1S Large/MaxNCALarge/Max packsHigh energy density; optimized for range
Rivian R1S StandardLFPSmaller Standard packLonger cycle life, thermally more tolerant
Mercedes EQS SUVNMC811~108–118 kWh depending model year; ~400 VConservative charging and thermal management
[th]
Peak DC charging​
[/th]​
[td]
>400 kW​
[/td]​
[td]
250 kW​
[/td]​
[td]
~220 kW class​
[/td]​
[td]
lower than Max/Large​
[/td]​
[td]
~200 kW​
[/td]​
Lucid confirms that Gravity uses Panasonic's newest 2170 cylindrical cells with more than 800 Wh/L at the cell level, while the vehicle operates at up to 926 V. The Grand Touring pack is 123 kWh.
1. Energy density: the Gravity's major advantage​
This is where Lucid really distinguishes itself.
The Gravity gets as much as 450 EPA miles from 123 kWh, while simultaneously carrying seven people and producing 828 hp. Lucid says the Panasonic cells exceed 800 Wh/L volumetrically.
That doesn't mean the entire pack achieves 800 Wh/L—cooling plates, structural components, wiring, crash protection and electronics all reduce pack-level density—but the cells themselves are exceptionally energy dense.
The Model X's NCA chemistry is also very energy dense, and Rivian's NCA Large/Max packs pursue the same general strategy. Mercedes' NMC811 is slightly different chemically but belongs to the same high-nickel family.
The alternative is LFP. LFP generally has roughly 20% lower gravimetric and about one-third lower volumetric energy density than NMC, although the gap continues to narrow.
For something like the Gravity, where Lucid wants enormous interior room without carrying a gigantic battery, nickel-rich chemistry makes considerable engineering sense.
2. Charging: Gravity wins decisively on architecture​
The Gravity can accept more than 400 kW from sufficiently capable high-voltage chargers. Lucid says it can add about 200 miles in under 11 minutes.
That isn't simply because of battery chemistry. The 926-V architecture is enormously important.
At the same power level, higher voltage means lower current, which reduces resistive heating and allows more power through the cable and battery system.
Even more clever is Lucid's solution for Tesla's lower-voltage V3 Superchargers. The Gravity uses its rear drive unit as a voltage booster, allowing up to about 225 kW at those stations despite the mismatch between Tesla's roughly 400-V infrastructure and Lucid's 926-V battery.
By comparison:
  • Model X: up to 250 kW on Tesla Superchargers.
  • Rivian R1S: roughly 220 kW maximum.
  • EQS SUV: about 200 kW, with Mercedes quoting roughly 31 minutes for 10–80% on the earlier 107.8-kWh pack.
So the Gravity isn't merely carrying a good battery. Its electrical architecture lets it exploit the battery unusually well.
3. Longevity: I wouldn't worry about the Gravity's nickel-rich chemistry​
LFP has an intrinsic cycle-life advantage. Rivian itself recommends different charging behavior according to chemistry:
  • R1S Standard LFP: periodically charge to 100%.
  • R1S Large/Max NCA: normally keep the battery around 50–70% and reserve 100% for trips.
Lucid gives essentially the same advice for Gravity: 20–80% is the preferred everyday range, and repeated storage at 100% can accelerate degradation.
For an owner who drives perhaps 10,000–15,000 miles per year, however, chemical cycle life is generally not the limiting factor. Modern battery thermal management and battery-management software matter enormously.
A large 2026 Geotab analysis of more than 22,700 EVs found average degradation of about 2.3% per year. Vehicles relying heavily on >100-kW DC fast charging showed higher degradation—up to about 3% annually—but normal use still produced quite long battery life.
4. Thermal runaway and fire: LFP has the chemistry advantage
This is where I would give the Rivian Standard-pack LFP battery the clear intrinsic advantage.
Nickel-rich NMC and NCA cathodes contain more stored chemical energy and become less thermally stable as nickel content rises. LFP's phosphate structure is considerably more thermally stable. DOE describes LFP's strong phosphorus-oxygen bond as one of the reasons for its resistance to thermal runaway.
Experimental comparisons generally find:
LFP
  • higher temperature before severe thermal runaway,
  • less violent reaction once runaway occurs,
  • lower energy density,
  • excellent cycle life.
High-nickel NMC/NCA
  • substantially greater energy density,
  • better cold-weather performance,
  • but a more energetic thermal-runaway event if a cell catastrophically fails.
One ORNL-linked experimental study found that high-nickel NMC cells had progressively poorer thermal stability as nickel content increased; LFP produced a much less severe reaction once thermal runaway occurred.
But here's the important qualification: cell chemistry is not equivalent to vehicle fire risk.
Actual vehicle safety depends heavily on:
  • mechanical protection of the pack,
  • cooling architecture,
  • cell spacing and propagation barriers,
  • monitoring of individual cells/modules,
  • crash isolation,
  • contactors and pyrotechnic disconnects,
  • battery-management software.
Panasonic says it had supplied roughly 15 billion EV cells by the end of 2023 without a vehicle recall attributed to the batteries, which is reassuring background for the cells Lucid selected.
I therefore would not regard the Gravity as a meaningfully unsafe vehicle because it uses nickel-rich cells.
Putting it together​
For the four SUVs, I'd characterize their battery strategies this way:
Gravity: maximize efficiency, energy density and charging performance. Lucid uses a relatively modest 123-kWh battery exceptionally effectively.
Model X: mature high-energy NCA architecture with perhaps the world's most mature charging ecosystem, but its ~400-V architecture now looks relatively conventional.
R1S Large/Max: prioritizes capacity, power and ruggedness using NCA. The battery is considerably larger than Lucid needs to achieve similar range.
R1S Standard LFP: sacrifices range/energy density in exchange for inexpensive chemistry, excellent cycle durability and inherently better thermal stability.
EQS SUV: conservative luxury-car engineering—NMC811, strong thermal management and relatively modest charging power rather than pursuing 350–400+ kW.
And this is the part I find most impressive about your Gravity: Lucid's advantage isn't primarily the chemistry.Panasonic, Tesla, Rivian and Mercedes all have access to very good lithium-ion cells.
The exceptional part is the system engineering around those cells—the 926-V architecture, very efficient motors/inverters, aerodynamics, thermal control and remarkably effective packaging. That's how Lucid gets 450 miles out of 123 kWh rather than solving the range problem simply by putting a much larger and heavier battery underneath the vehicle.
TLDR
He charged to 85% not 80%.
What prompt did you use for your query?
My bad. Apologies. I contacted two engineers, didn't do a search.
