Is it me or the software ?
Eugeneflorida
Saint petersburg
2019 Lincoln Navigator,
I had a 2022 Y. Getting in and out the seat would auto adjust.
My 2026 GGT I can get the seat to auto adjust in the driving position but then to get out, I can not also have the auto adjust working.
After manually adjusting the seat to get out, the seat some times moves from were I had it befor I get in.
My easy access works fine in my 2025 AT.
So it's the exit you're having the issue with correct? I've noticed something similar, it doesn't move back when you park the car \ open the door but when you return to the car the seat is back and will adjust forward when you get in. Basically the entry part of the Easy Exit\Entry but the exit doesn't.
If you mean will it remember your preferred exit/entry position, no. It doesn't "auto adjust" to your preferred position for exit/entry. It has one default exit/entry position that is the same for everyone.
Then when you get in again it will move to the saved driving position. Open the door to exit and it will move back to the default exit position.
It doesn't "auto adjust" for exit. It has one default exit setting that is the same for everyone. Then when you get in again it will move to the saved driving position. Open the door to exit and it will move back to the default exit position.
Yeah, I wasn’t sure if this was an issue or not but I could’ve sworn that the Air adjusted for exit. Can any Air owners confirm or am I remembering wrong?
It does adjust for exit. It just goes back and you can't set how far back it goes.
I mean it adjusts, just not to a preferred position.
In Teslas you can save separate exit and driving positions, which is what I think OP might be talking about.
Guess I’m on the potential list of it’s not working properly then. Will have to check it out more as the entry is working as intended.
When you open your door the seat doesn't move back?
(and you have it enabled)
No, BUT...... I haven't been paying really close attention. Popped in my head the other week where I thought "I don't think the seat is moving back" and should pay more attention. The OP just reminded me to check again, maybe I'm not going crazy :p
When I return to the car though, the seat is back and moves forward as expected which is why I also thought, maybe I'm just not paying enough attention upon exit. Will pay more attention next time I'm out for a drive.
Yeah I mean...
If it moves forward to a saved driving position it obviously moved back to the easy exit/entry position.
For me, 25 Air Pure, Easy Entry works when exiting the vehicle. Seat slides back and steering wheel moves closer to the dash when I either open my door or manually put it in park.
When I am leaving, I get in and close my door then the seat slides into my preferred position.
You are not going crazy, my Gravity does not do the easy exit part but does do the easy entry part.
Sometimes it works, sometimes it doesn’t. No rhyme or reason. Awaiting the long overdue update to fix many of these sporadic issues. A reboot may help. Manually moving to the extreme positions also helps occasionally.
Mine works, it's just not always done when you're getting out. It doesn't move until you open the door and the car is in park, I find I'm often already partway or all the way out of the car while it's still moving.
I had may issues with my seat but it all got resolved after doing a seat homing
Ask Lucid for a seat homing
