I’ve had my Gravity for a month and it’s lovely. I can’t seem to find an aftermarket spare for it. Does anyone know of a company that supplies one yet
Sarah
2026 gravity
I’ve had my gravity for a months and it’s lovely. Does anyone know of a company that make s a spare for this car?
You meant "spare tire"? Not that I'm aware of, but I'm certain some tire geeks here could help you find one that will fit your need. @037 any idea?
Depends on your specifications. In an emergency, Tesla Model X wheel is a direct fit, but you need to get the tire size right. Land Rover has some wheels that are a direct fit with a centering ring, Rolls Royce Spectre is another one…it’s complicated but a spare tire could be anything as long as the specs match up.
I only went through 5 wheels before stopping on one (purchased 2).
So if I want to have a full size spare for the 21/22 tire combo, which wheel and tire would you recommend?
Would I be ale to use the wheel in the link below for the front?
Assuming that I could use this, can I use the existing lugs?
Thanks.
Thanks.
I see no obvious issues with the wheels in the link, you will need tuner style lugs.
Assuming it’s a low speed spare you don’t need to worry as much about actual tire being different than the rest, just make sure the tire size matches as Model X uses different size tire.
If you need just one wheel I would go to TireRack and pick the lightest wheel of whatever color and pattern you want that is Land Rover spec as it’s the same bolt pattern, you would need a center ring, but at least the weight tolerance will be similar. You want 2,000lb per wheel at the least. Max Gravity load is 7300lb and the rear requires more than the front.
I personally went with 2200lb wheel load.
