Gravity w QuikrStuff Bike Rack
raleighone
Gravity 5 seater
Just thought I'd share in case anyone was curious about this and wondering about adding a rack/bike. I installed the QuikrStuff Mach 2 bike rack after adding the hitch receiver to my Gravity. Both adding the receiver and installing the Mach 2 rack were super easy and tool-less. Both take less than 20 minutes to install out of the box.
It's my first time adding/driving with a bike on the back, so I was a little nervous. But the Mach2 really lets you get the bike very stable and locked in, so very little bounce or movement, even with my fat tire e-bike, which is on the heavier side. (I'm right near the max limit of ~118 pounds with the rack (30ish) and bike (80ish.) I put handlebars down and bungied them to keep compact.
With the bike on, you have to go into settings and change: DreamDrive-Rear Attachment Optimization. So DD worked fine for highway driving, lane centering, etc without issues. However, every auto-lane change would trigger a warning and I usually had to "push" it into the next lane a bit before it took hold of the new lane/lines. Kinda annoying...I actually just started manually lane changing. Not a huge deal.
Like most racks, it does unlock and fold down with the bike on the rack to allow you to open the back hatch. It also folds up if no bike; the hatch will open fine and there are also no issues or warnings with DreamDrive lane changes, etc.
Overall, great setup for the Gravity.
Nice job with the hitch setup. I’m not gonna lie, the pics make me nervous. Please report back to us after you’ve used it for a while. The durability of the cantilever concerns me. I also have the hitch and the underneath vertical insertion of the hitch receiver seems like a bad design for attachments, but I’m sure there was a reason for the compromise (I guess not putting a hole with cover in the back bumper? Horizontal attachment would’ve been better).
Have you had any issues with clearance or concern on bottoming out? Particularly backing up, I have a moderately steep driveway and this will drop clearance and extend it out too, I haven’t put the hitch on yet to test but I couldn’t really see from your pictures. Are you planning to keep the hitch on as well or take it off when not in use? Thx for the post
Hmm...I haven't had it bottom out anywhere. It sits above the lowest point of the car, so I'm guessing it'd be fine. You could always keep your car at a raised height when in your driveway.
I haven't taken mine off since I put it on and will probably keep it on. That said, it is very easy to install/remove and doesn't require tools.
