- Sep 30, 2025
- Silicon Valley adjacent
- Gravity GT
- CA8VVCF7
Short story: It works!
Longer story: I have a Gen-2 Tesla mobile connector left over from a previously leased 2020 Model X. I plugged it into my NEMA 14-50 and then into Gravity, and it charged at 7kW with the battery at 75% SOC, so I expect to get the full 9kW when the SOC is lower, same as the Gravity GT included Lucid mobile charger.
So, why did I care?
Because the Lucid doesn't support a 3-prong 30amp NEMA 10-30 plug adapter. Lucid includes 14-50 and NEMA 5-15 (12 amp, 120volt) adapters, and you can buy a NEMA 14-30 adapter, but if you're in an older home with a 3-wire Dryer out (10-30), I think you're out of luck with the Lucid charger, but should be OK with the Tesla Gen-2 (and Gen-3) adapters. That said, the Gen-2 Tesla adapter doesn't support power out from the vehicle like the Lucid charger does. The Tesla Gen-3 does, but I don't know if that works with Gravity. And, small thing, the Tesla bag is smaller than the Lucid bag.
I suppose one could wire up a short Frankenstein cable that has a 10-30 plug and a 14-30 outlet, wire the neutral and grounds together, and get the Lucid to work, but that's probably a bit sketchy.
So, why did I care?
