Experience with the V2V charging cable?
jrreno
Sarasota, Florida
2026 GT Gravity
Has anyone had any experience with the vehicle to vehicle charge cable offered as an accessory to the Gravity?
One detail I am curious about is the stated limitation that it only works with specific mobile chargers and not the one I was given with our new Gravity.
All Gravity vehicles have the newer mobile chargers included and are compatible with the v2v charging cable. The non-compatable mobile chargers were included with the Air.
It works great. Once in a while, I use it to top off our other EV when my utility electricity rates are high and the Gravity has plenty of energy.
There are two versions of this cable. One is J1772 and one is nacs. Since most have the J1772 to nacs adapter it seems the J1772 cable would be the better choice allowing charging of both types.
There are two versions of the mobile charging cable, and two versions of the RangeXChange accessory cable.
Buy the RangeXChange accessory cable version that matches your donor car. Air - J1772, or Gravity - NACS.
Then buy the mobile adapter that you think will be most useful to you, if you don't already have one. Personally, I'd buy the NACS version since it will be the eventual connector for all EVs going forward. And I keep a NACS to J1172 adapter on hand.
