Drowsy Driver Warning Keeps Coming Back Every Day
coupedncal
San Francisco Bay Area
2026 Lucid Air Pure
Since the last two software updates, I have this issue of drowsy driver alert flashing during long drives. I turn off the feature EACH time by sliding the option to off in the Dreamdrive settings and it comes back to enable for the next drive. It only shows up on longer drives and does not appear in local city short drives.
I am sure mine is not the only car with this issue. Mine is a 2026 Pure. Are there other drivers also seeing this bug?
I am currently on 2.10.0
Isn't the drowsy driver alert also something which is required by law to auto enable each new drive? At least in Europe it is. Same with speed limit. This needs to be changed to off each new drive.
Correct. European regulations require all safety features to be turned on for each new drive. It’s easier to follow all regulations rather than try to customize per country.
Just checking if this behavior is consistent across trims. Someone with a Touring had mentioned in another thread their car did not do this and they were on 2.10.0 code.
Mine is a Pure.
