- Nov 19, 2021
- Cupertino, CA
- Air DE-P, ZR, 21"
- DE Number
- 241
- Q1BTN5Y3
The paper manual is abridged to only the “important” bits (saving trees).Thanks, Borksi. Only way I found to engage ACC was to push in on the horizontal silver bar on the stalk above the 3 button array with the cruise control icon, the distance icon, and the “X” to disengage. I thought the lower, left hand “cruise control” icon would engage ACC. No such luck. Depressing the silver bar that was part of the +/- 1 or 5 MPH increments was, ultimately, the only reliable way to engage ACC.
I have not looked at the manual on the iPhone app and the little booklet in the glove box labeled “owner’s manual” is surprisingly lacking in detail and seems mostly many pages of warnings.
Any other thoughts would be appreciated. Overall the Air is AMAZING. Truly impressed. Thanks for your leadership with these pages.
The in-car screen manual and iPhone manual are the same.
For ACC, you first “turn on” ACC with the little speedometer button. Then you set the speed. If you don’t hit that speedo, you can’t set the speed. But the speedo does nothing except activate and deactivate the feature. The rest of what you did was correct. Set the speed with the wheel, cancel speed with the X, turn off with the speedo.
At a full stop, tap the accelerator or “increase speed by 1” using the wheel (which it won’t increase, but just set it back to the old speed).
