Delivery process for 2 drivers
skywaterbanjo
Durango, Scottsdale
When taking delivery, I assume they walk you through the setup for profiles. Should we do 2 separate deliveries, setting up 2 profiles, or do them both at the same time?
TIA
I think a second delivery is overkill. You can set the two profiles up at the same time.
My wife and I took delivery together. Only one profile was setup. We got home and repeated the steps for the second profile. It was very straightforward.
If you want help setting up the profile, definitely do it during delivery. They're very very accommodating to customize the delivery process.
Thanks!
You can set up both profiles one right after the other. Two deliveries makes no sense.
They will set up both profiles for you during the same delivery, one after the other. You just need to let them know you're bringing the second person to the delivery date so they can make sure there is time.
You let someone else drive your Lucid??? 😂 :cool:
The way you wrote the question, when I first glanced at it, I thought you were having 2 Lucids delivered at the same time and was VERY jealous! 😂
