Cannot change rear passenger display temperature from F to C
mickey6
Tesla X, Tesla Y, Taycan
I did a search but could not find a definitive answer. The units and measurements are set to Celsius under settings and the center console displays temp in Fahrenheit. However the rear passenger display shows temp in Celsius - Any way to fix it or is this still a tracked and reported bug? I have tried toggling from C to F and back to C and also rebooting but has not worked.
Did you ever find a solution for this? I just picked up my Gravity and noticed the same thing. The Pilot Panel has the temps in F but the rear screen is in C.
I had this and it seemed to fix itself. I did go into settings and flipped the units to Celsius and back to Farenheit after my sister noticed it was wrong while sitting in the back seat. Perhaps it has something to do with the panel being off when the back seat is unoccupied?
You probably try a lot of things but as suggestion I would try to set the rear and front climate completely off before flipping between F° and C°. In the Air the back screen climate function is "off" if there is no butt on seat. (Don't know about gravity) Than check that your outside t° in right cockpit panel, climate control (front and rear still "off") in pilot panel are showing the unit you selected then after select "sync" in pilot panel climate control (on/off button will lightup and the system will start) and hopefully the right unit will be push in the rear panel. Try the same with the the Rear Display lock or unlock (in pilot panel) if it doesn't work. Just my 2 cents. Good luck !
You seem to be right. I just sat in the backseat to activate the rear climate control screen. Then switched the units on the Pilot Panel between C and F and the rear screen switched to F.
