Air at Tesla Supercharger with 3rd Party Adapter
Cabonzhp
Lucid Air Pure
With the new update, has anyone attempted to use a 3rd party CCS NACS adapter at a supercharger? Lucids wording seems to imply that only their offering will work. Happy to give it a try as work has a few 3rd party adapters lying around.
Honestly I’d buy a Lucid adapter, or try to get a Refferal by bringing someone else into the Lucid fam.
The Lucid adapter is very robust and will work great. A lot of the less expensive ones online seem like they are a bit of a bet and hope.
If you have an Air, a 60-155k investment I’d spend the 200+ on an OEM plug. Or the time to reffer someone to this great vehicle/brand to pick on up on the Refferal store.
As best as I can tell, the Lectron adapter is the same as the Lucid. Same specs, same packaging, same appearance with the exception of the branding. The Lectron is quite heavy and well built, again apparently like the Lucid version. I’d be surprised if Lectron or its supplier doesn’t make the adapter for Lucid.
I ordered it because it was immediately available. I haven’t tried it and probably won’t be using it much, if at all, but the online reviews are very good.
I've had a third party one from Amazon for 3 years, never a problem with a Tesla charger at friend's house
That's a different adapter. You have a Level 2 (AC charging aka NACS to J1772) adapter. it won't work for DC fast charging. You need a NACS to CCS1 adapter for that.
They do work, but safety is another matter. Lucid's DC fast charging adapter isn't expensive and is readily available.
