Ionna Thanksgiving Holiday special
ClearlyLucid
Atlanta, GA
2026 Gravity DE
Gravity DE Number
195
OW6JOVYZ
FYI, for anyone traveling Ionna is running a Thanksgiving Holiday special of $0.20 kWh from 11/25-11/29. That’s almost a 50% savings off of the already low rate of #0.39 kWh. Ionna stations offer up to 400 kW DC fast charging. Our Gravity is one of the few cars that can take advantage of that speed.
Look out for the free bent connector pin special though...😂
But joking aside, that's a great deal. EA standard rate in California is $0.68 kWh - what my dad used to call highway robbery. Just wish there were more Ionna charging stations around.
Can you elaborate on the “bent connector pin”?
,Just in case anyone is needlessly worried, NACS connectors are not affected (this thread being on the Gravity forum). It was some CCS connectors in the midwest.
@ClearlyLucid https://lucidowners.com/threads/charging-issue-bent-pin.17318
And a synopsis from Mercedes: https://mercedesbenzhpc.com/ccs-pin-update/
Yeah, I used the NACS connector at Ionna. Inspecting the pins before charging is a good idea, whether NACS or CCS. I will be doing it from now on.
Perfect timing. I’m on my way to Colorado now, and have been using Ionna where I can. They work great. I’ll be traveling back to SoCal right after Thanksgiving, so looking forward to taking advantage of the discount. Even though chargers in the Midwest seemed to have been affected by the bent pin issue, Ionna has put a message on their screens in NV and UT to encourage checking the charger pins.
