Gravity Screen Protector Kit recommendations
arunim
2034 Lucid Air Touring
ABLM7DKB
Does anyone have any recommendations for a good screen protector kit for all 3 screens? (clear view, cockpit and rear)
Thought about this too, but it's overkill.
Are you kids throwing rocks inside the cabin?
Sort of wish I had just left the protectors that came with the car...
I'd be up for matte ones. TWraps have them for the Air. So I guess watch that space and see as one option.
that's what I've done for now. My Land Rover has had its on for over 3 years. :D
Anyone find a good rear screen protector? I tried one on eBay, but it wasn't great...
No nothing so far. I have spent almost a weekend searching but nothing.
I see this as an opportunity for someone to start building it.
If anyone finds it pls do share. It’s needed when you have kids in the car.
For the Pilot Panel screen in front I just bought a matte laptop screen protector and cut it to size. It's not perfectly fitted but good enough for now and the matte really helps with glare.
The only screen protector I have is a hard matte one for the lower pilot panel. The matte finish really minimizes fingerprints and glare, neither of which is an issue for the upper Clearview cockpit. I do recommend a matte protector for this lower screen since it's typically touched more and can have a bad glare seemingly quite often. While I have a hard one, a soft one should work too. The screen is 12.6inch and 9:16 (standard widescreen). I ended up getting this one for myself. It's actually only 12.5in so it's about 1mm smaller on all sides than the illuminated screen, but it doesn't look that bad. The screen protector itself is really nice, but now not sure worth the $50 I spent. Honestly though, there's enough non-illuminated bevel around the display that I think a 13in 9:16 screen protector would fit perfectly with the edges somewhere in the middle of the bevel.
I'd actually recommend anyone looking for one to get a 13in 9:16 hard matte screen protector for the pilot panel only.
If you look on Amazon at that one, someone bought it and it doesn't 100% cover the screen. I don't know if I consider that a dealbreaker but it definitely isn't as custom cut as they say it is: https://www.amazon.com/BoxWave-Protector-Compatible-Gravity-Display/dp/B0FHNB2231/
Although I see they have a second, more recent listing for it. I don't know if that means they revised it or they were trying to dodge bad reviews.
Ali Express has a kit for all three gravity screens. Cost me like $22. Have only applied pilot panel. Sort of a pain to apply but I do not even have a screen protector on my phone and never have a problem. Anyway it looks decent. Trying to get up courage to do big screen but also agree with some, why bother.
Do you have the link?
Thanks.
If that does not work just search Lucid Gravity screen protector. Pops up on my phone under Ali Express.
I bought one from ali Express just for the rear screen with the kids...works well.
