Considering OEM-19" wheels on my 2024 Lucid Air Touring
JChao
Lucid Air
I currently have the factory 20-inch wheels on my 2024 Air Touring. I am considering changing to the OEM 19-inch setup because ride comfort and efficiency are more important to me than sporty handling. I would be interested in hearing from owners who have made the same change.
I've had my 19s for four years. I've also driven the Air Touring with 20s and 21s.
The 19s are good tires. And they last long, too. Never had any issues with them. I chose them because I lived in Colorado at the time and I needed All-Season. And the option to swap to snow tires in the coldest parts of the winter.
They definitely can't perform as well in a launch as the 20s or 21s, but like you said, speed and sportiness are not your priority. They definitely do well enough with spirited driving. I never felt like they couldn't handle what the car was putting them through.
And the range increase is real. I never put on the aero covers, which would make them go even further, but the difference is not worth the uglier look of the 19s with those covers on for me.
I specified 19” tires when I purchased 3 years ago. I also wanted to maximize efficiency and robustness for New England roads. For the past 17k miles my average is 4.04 miles per KWh. At 27k when tread depth was checked, I had 7/32 of the 9/32 when new. That’s darn good in my book.
I think you are in Southern California like me, is that right? My GT-P came with the 21-inch wheels and summer tires but I've been driving around for 50K+ miles now on the OEM 19-inch wheels w/ all season tires. I can let you drive my car if you want to get a feel for the 19's....feel free to DM me if you want to see about connecting.
I haven't been as fortunate. My 2023 Air AWD Pure has just under 23,000 miles and I have 5/32nds on 2 and 7/32nds on the other 2 (just rotated again so the 7/32nds are on front). I have, however, seen as good as 5.15 miles per kWh on my road trips to/from Phoenix/Chicago. I'm wondering if my big road trips involve roads that wear tires more because I'm always in smooth mode and not big on ripping it fast, etc.
4.04 miles per KWh! Wow... 👍 Thank you for sharing.
Yes, Orange County SoCal. Thank you for offering. What's your best miles/KWh?
I just started using LucidTracker recently:
So, you swapped the 21-inch wheels on your GT-P to 19-inch wheels?
Yes.....I made that swap two years (and 50K+ miles) ago.
Professor,
May I ask where you went to swap your wheels and tires from 21" to 19"? Did you use an official Lucid Service Center or somewhere else? Also, did you sell your 21" set to a private party (via the Lucid Marketplace) or to a wholesale business? I just want to get an idea of the process and get your professional recommendation. Thank you!
Professor,
I don't know about professional recommendation but I'm happy to share experiences!
I got my OEM 19-inch wheels + tires + labor all done at Lucid Costa Mesa. My work order is attached. It was all seamless from a customer perspective. It took maybe a week for Costa Mesa to get it in, and then I went in the next day and they did the swap and I was in and out in maybe 30 minutes or so. They also bagged and helped me place my OEM 21-inch wheel + tires in my car as well.
But that was 2024 and service is super backed up these days....however, the new Mission Viejo location is going to be opening here real soon and they have I think 18 new service bays there at the new location so that should start easing the bottlenecks.
Professor,
I got mine at discount tire, aftermarket. Went from 20 to 19.
Thank you for sharing. I started shopping around for wheels and tires. It's easy to find a 19" set, but it's hard to sell my stock 20" wheels.
Wow... amazing. Thank you for sharing. I plan to sell my stock 20" set and replace them with a 19" set. For some reason, I just cannot get good range efficiency. My trip A odometer, which tracks the car's total mileage, shows 10,900 miles at 3.05 miles/kwh. My trop B odometer shows over 250 miles at just 3.01 miles/kwh.
I just kept my 20 inch as backup. Had a little curb rash so wasn’t going get much for them .
is there actually a big difference in handling between 19 and 20"?
Can’t say about the 20’s but a big difference with the 21’s over the 19’s
Better inherent range on the 19’s, but the 21’s have better stability when cornering. I suspect a similar difference yet smaller.
