but notice I’m using a USB to play my curated playlist while simultaneously getting Lucid
SighView attachment 40609Took a 3 hour drive today and blown away by the progress since I bought my Gravity last September. So much going on here - the CarPlay giving me real time Waze info - but notice I’m using a USB to play my curated playlist while simultaneously getting Lucid Map instructions and Song info via the Pilot interface so I can use the lower screen to validate my preconditioned state. Oh - all while driving hands free! Was it worth a years wait? Absolutely…
I used M4A/AAC files — 256 kbps, 44.1 kHz. I built the USB from my local music library and organized the files into a clean folder structure for the Lucid. It’s been working perfectly so far.Awesome. Which audio format did you use on the USB?
Do you have search access like the was years ago? Plug in your iPod or USB, and be able to search playlists, songs, albums etc.I used M4A/AAC files — 256 kbps, 44.1 kHz. I built the USB from my local music library and organized the files into a clean folder structure for the Lucid. It’s been working perfectly so far.
Ok, I reported this to SW team but ever since 3.6 my USB which is always in USB 1 slot (closest to driver) flips everything to USB 2 ... where it plays fine, but you get out of car and come back it continues playing last song, actually a portion of it then cuts off. Go to music screen it will show the portion of last song played on USB 1. But the music is on USB 2 so you have to reselect and it plays fine until car is off and it repeats all over a again. Does yours do this? If I move USB drive to USB 2 port ... it flips it the other way. Rebooting the car does not fix.I used M4A/AAC files — 256 kbps, 44.1 kHz. I built the USB from my local music library and organized the files into a clean folder structure for the Lucid. It’s been working perfectly so far.
It does 100%. I only noticed it on this drive. Exactly as you stated - starts back last song then stops. I didn’t notice the flip but now that makes sense. I remember some confusion finding my Folders. So yes - same with my set up.Ok, I reported this to SW team but ever since 3.6 my USB which is always in USB 1 slot (closest to driver) flips everything to USB 2 ... where it plays fine, but you get out of car and come back it continues playing last song, actually a portion of it then cuts off. Go to music screen it will show the portion of last song played on USB 1. But the music is on USB 2 so you have to reselect and it plays fine until car is off and it repeats all over an again. Does yours do this? If I move USB drive to USB 2 port ... it flips it the other way. Rebooting the car does not fix.
