World first: 315 rear on 22x11 custom wheel
037
Gravity GT custom wheels
275 front, 315 rear. Let’s put those Porsches on notice.
Looks great. That will be one dirty front door and rear lower quarter panel though with those wider tires.
I ran similar in width setup for the winter and the sides are nothing compared to the sh1t storm happening in the rear.
Nice enough, are you considering any body work to sweeten up the aero
Nope, it’s stable as is. Just gotta find some time to do some brake testing to see if I can hit Cayenne EV Tuebo territory, 70mph under 150 feet and 100 in under 300 braking.
You are making the changes im going to make when I get my GT-S . 🛠️🏎️
That looks awesome! 🤩👍
  • Like
Reactions: 037
Nice...can you share your wheel and tire specs?
I haven’t done launch or brake tests yet, want to make sure things keep working.
Put on couple hundred miles yesterday and working as designed.
The spec, now that the braking and acceleration runs are done without damage to feelings or property.
Might as well add the braking data here
Need to correct the rear tire to 315, typo.
Confirmed accelerates fine.
That SUV is pretty fast for its size and weight.
Quick question, is your range better on 22 all around compared to having 23 on the rear?
I haven’t driven very much on 22/23” and generally take little note of range as it’s either city traffic and highway traffic or cruising comfortably on the highway and away from other cars.
