Just noticed that either the driver or the driver rear door’s bottom plastic trim is loose. When I opened the driver side rear door, I noticed that the edge of the plastic trim was rubbing against the inner edge of the driver’s door bottom plastic trim. This caused scratches on both doors’ plastic trim. Not that noticeable on the driver’s trim, but noticeable on the driver rear trim. I was able to push both trims opposite direction of each other to mitigate this. Probably the adhesive holding them in place became loose and shifted both trims or just shifted one trim. Service scheduled.
Has this happened to anyone else before?
