Gravity 19” all around
psulightning
Baltimore County, MD
2026 Kia EV9 Land
Was curious if the gravity supported 19” for all four tires or if anyone has configured. Was thinking it would help performance but I imagine the engineers have the 1” front/back difference for a reason.
Gravity's smallest wheels are 20/21". The rear wheels are larger just for looks.
This wheel configuration gives a very comfortable ride.
This being the case, can one go 21' (or 20') square then?
If you search here, you can probably find posts from a member who converted their Gravity to a square setup. I don't recall which size they chose.
Actually, I think they picked the same wheel diameter for all four corners, but are running wider rubber in the back.
Actually, I think the picked the same wheel diameter for all four corners, but are running wider rubber in the back.
I think you're right.
I believe they got after-market wheels and had modifications that I have no clues.
