- Aug 2, 2025
- Lucid Grand Touring
The glare of the sun’s reflection off the metallic HVAC buttons of the Air ranges from annoying to painful and possibly dangerous. At one point on a long drive the glare was causing so much pain (similar to snow blindness) that I had to pull over and ask my wife to continue driving. So, I decided to make a cover for these buttons to eliminate the glare. It’s not pretty but does the job. I made a template using graph paper and then cut the cover out of three inch wide gaffer’s tape. The top surface of gaffer’s tape is mat black to absorb light. The adhesive is not supposed to leave a gooey mess when removed. Not sure if true over long term. I attached a two inch strip of black paper to the underside of the gaffer’s tape leaving only one inch strip of adhesive on the the bottom that attaches to the wood trim. THE FOLLOWING IS VERY IMPORTANT. What appear to be to be metal buttons are actually pieces of clear plastic that are covered with a thin layer of metal (aluminum paint?). If you attach adhesive tape to the HVAC buttons, it will remove some of the metal when you remove the tape. Ask me how I know. The one inch wide adhesive left is quite adequate to hold the cover in place. Notice I cut a rectangle for access to the volume control wheel and wrote “Temp” and “Fan” on the black cover using a white pencil. I’ve attached a photo. If you have a better solution I’d like to hear about it.
