Max summer tire - 100-0, 70-0, 60-0 braking
037
Gravity GT custom wheels
Large Lucid wheel, Goodyear Eagle F1 Assymetric 6 in 275/40/22 and 295/35/23 size
A solid improvement over oem Pzero 5.
The braking was down hill slightly, which made the distance longer than necessary.
High regen.
For science.
Probably worth mentioning both front and rear tires are under $2,000. Even cheaper if front is a 265 stock size.
I just went to Discount tire yesterday to have the right rear tire replaced (screw puncture) and out the door installed with tax the tire was $550. The fronts are slightly less so I'd guess to replace all four tires (20/21 inch) it would be around $2100 with the OEM all season tires
Thanks for sharing and sorry about your loss of tire.
I was referring to the 22/23” setup with 23”s running about $950 before tax/install.
