- Nov 23, 2023
- Arizona & Washington
- Pure AWD 19" No Aeros
- MAXED
Could you take a pic of the spot you’re talking about that the service tech adjusted, or that was misaligned? I’m curious but had a hard time visualizing it based on your description. Also, I did try @Bobby trick of lubricating the seals (including the windshield and glass roof seals!) from his YouTube video. While my car did not suffer from the excessive wind noise some have described here, mine did have some buffeting seeming to come from the drivers door corner near the mirror, and Bobby’s fix did noticeably reduce the noise, not making it zero but it did reduce it more than I expected. Before that I had tried stuffing a microfiber towel in the corner by the mirror with zero improvement. This makes me think that the airflow is not going in via an isolated gap, but rather the air is going over some unevenness that develops over time with the numerous seals along the entire door/window/glass roof creating a hard to localize perception of wind noise. At least for my car I really do not mind the wind noise I had before I tried @Bobby fix, it just made me think of a glider flying through the Air. But it does sound like a few owners are having more dramatic air noise issues than my car.
Per your request, here is a photo of the black strip I am talking about. With the door closed, pushing on the top of it will roll the strip a little closer to the body of the car. The objective is to gets the strip on the passenger door to stick out no further than the same strip does on the driver door, but it will also push the horizontal rubber gasket behind it a little closer to the body frame. If you actually open the door and roll it gently with both hands, you get more movement than you would if you just push on it with the door closed. While my service tech seemed to think that the improvement was due to a cleaner air flow, I think it's at least equally possible that getting that rubber seal in a little tighter may have had the bigger positive effect. Whatever the cause and effect, at least in my case, it seemed to help.
